Another Central Locking Problem
Discussion in 'Z3 Roadster & Coupé' started by jonco, May 6, 2014.
  1. jonco
    jonco Zorg Guru (III)
    Supporter British Zeds The M44 Massive
    Dec 6, 2011
    1,324
    664
    149
    Chester
    Model of Z:
    '98 1.9 Auto
    Hi - need some help on ETM interpretation and tests - can't see wood for trees at the moment.:confused:
    Fault - Passenger door will not lock by remote or key from driver's door or boot. However, inserting key in passenger door will lock/unlock both doors and boot. One way traffic!
    I know usual suspect is boot `loom of doom' but I inserted a new DIY section of loom (~18months ago) and all- worked Ok until now. Have checked continuity on inserted section and all seems ok.
    Removed passenger door card today and revealed part of door loom (see pic) but unable to work out which is input signal wire and which is output. Also don't know what voltage I should be seeing. Any ideas please?
  2. badman gee
    badman gee Guest
    Sounds like the door actuator has failed. Quite common. Mine went last year on the drivers side.
  3. badman gee
    badman gee Guest
    • Like Like x 1
  4. jonco
    Dec 6, 2011
    1,324
    664
    149
    Chester
    Model of Z:
    '98 1.9 Auto
    Thanks Mark - you`re probably right. I'm was trying to eliminate wiring fault first before buying one. Did you buy new or second-hand? Cheers Colin
  5. badman gee
    badman gee Guest
    Not only that, the same company sell water pumps with metal impeller and warranty.
  6. GazHyde
    GazHyde The Gaz Monkey
    Dec 2, 2011
    15,105
    9,171
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    The passenger door lock on my silver Zed was prone to all sorts of strange behaviour which traced back to the door actuator as Mark suggests. Checked my boot loom wiring and it looked fine from what I could see!
    • Thank You! Thank You! x 1
  7. badman gee
    badman gee Guest
    It's common for the actuator to work intermittently before complete failure.
  8. jonco
    Dec 6, 2011
    1,324
    664
    149
    Chester
    Model of Z:
    '98 1.9 Auto
    Just followed your link - and yep they're good I bought my new Myle pump from them last year.
    • Agree Agree x 1
  9. badman gee
    badman gee Guest
  10. hard top
    hard top Zorg Expert (I)
    Dutch Zeds The M44 Massive
    20,673
    6,020
    213
    Netherlands
    See, piece of junk. Was the replacement part especially polished for you?
    • Like Like x 1
  11. badman gee
    badman gee Guest
    Yep polished until purple!
    • Like Like x 1
  12. t-tony
    t-tony Zorg Expert (I)
    30,190
    14,242
    220
    Model of Z:
    Z4 3.0 Auto
    Euro car parts supplied mine last year at reasonable price.
  13. jonco
    Dec 6, 2011
    1,324
    664
    149
    Chester
    Model of Z:
    '98 1.9 Auto
    Update
    Wiring checked and appeared ok. New Meyle actuator from Motomec (ebay) - £52.95. Fitted and now working Ok. Thanks badman.
    For those who haven't changed one it's fairly straightforward - biggest problem I had was getting rear window guide back in.
    Good news was door internals were corrosion free :).
    • Like Like x 2
  14. t-tony
    30,190
    14,242
    220
    Model of Z:
    Z4 3.0 Auto
    Glad you got it sorted ok. You could have gotten 2 from Euro's for that price tho, and they OEM spec.;)
  15. jonco
    Dec 6, 2011
    1,324
    664
    149
    Chester
    Model of Z:
    '98 1.9 Auto
    Hi Tony, After your first comment I searched on euro parts and Carparts4less they were not coming up as available - I'm about to give the cat a kick - the furry one that is!
  16. t-tony
    30,190
    14,242
    220
    Model of Z:
    Z4 3.0 Auto
    Got mine from Euro's in Lincoln mate. Got it at trade price I forgot to say but that's not too big a difference with then to be honest!
    • Like Like x 1
Share This Page
