Aircon gas recharge
bombur
Porthcawl, Wales
Z3 1.9, Z4 E89 2.3
Used a Groupon deal and Top Cashback to get my AC recharged at ATS today for £30. No AC before now like a fridge :) Was told the Z3 has 1kg of gas which is a lot and more than the average 600/700 on cars, think there was about 100 in mine!
A Z3 does have 1kg. If it had only 100g left it probably has a slow leak so don’t be surprised if it loses the “icy” feel. Remember it’s only a 2 seat car with a small cabin, so doesn’t require a huge amount of refrigerant.
bombur
Porthcawl, Wales
Z3 1.9, Z4 E89 2.3
A Z3 doesn’t have a kilo of gas in them I’m sure. If it had only 100g left it probably has a slow leak so don’t be surprised if it loses the “icy” feel. Remember it’s only a 2 seat car with a small cabin, so doesn’t require a huge amount of refrigerant.
yes was thinking that myself about a possible leak. how easy (or not) is it to find one?
The recharge ought to contain a dye which, using a UV light is easily spotted.
ps. I was sceptical about a Z3 holding 1kg but having checked on Autodata , they say it does. I’m surprised at that my Z4 only takes 750g.
bombur
Porthcawl, Wales
Z3 1.9, Z4 E89 2.3
Shouldnt they check if there is a leak prior to recharging? they took about 45min in total
No they won't do that as the machine has to create a vacuum in the system.prior the filling the gas. A small leak is unlikely to be detected by the machine creating the vacuum so they will assume all is well. It could last a good while, hope it does.
motco
Chilterns
Z3 2.2i Sport
The place I took mine to commented on the surprisingly large size of the charge.
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
I had my aircon recharged a few weeks ago 🌞
It worked for the first week and then it stopped working 😲
I took it back to where I had it done , they said I’ve got a leak but it didn’t show up because it was too small for the machine to pick up on 🤭
They gave me my money back , which was good off them 🌞
bombur
Porthcawl, Wales
Z3 1.9, Z4 E89 2.3
Maybe I can check at ZedShed Cymru next week @colb? ...thats if there is any gas left by then lol
That's poor, very poor. They should do a pressure dye test first as they did with mine and found a condenser leak. As a AC engineer told me, the only non mechanical reason for AC failing is a leak, the gas just doesn't evaporate.
People rely on the vacuum creating to find a leak, use it as a short cut.
DrWong
3.0i
Just looked at the Groupon page. Small print says a pressure test is carried out prior to recharge and if a leak is detected, the recharge doesn't proceed and Groupon issues a refund: ATS Euromaster - Up To 40% Off | Groupon
I may have to move on this as well, seems like a win/win
bombur
Porthcawl, Wales
Z3 1.9, Z4 E89 2.3
I guess they could tell me the leak (if I have one) wasnt detected as was small.
bombur
Porthcawl, Wales
Z3 1.9, Z4 E89 2.3
Back in having a Inspection of the A/C. They said machine has been playing up so could be that or a leak. Pressure test done again and all fine so filling it back up. Said they have put the uv dye in this time (I thought that was standard practice? 😮)
