Aircon advice E85 with inpa
Bigwinn
Lincoln UK
Z4 3.0i
Afternoon all
trying to get to the bottom of why my aircon isn’t functioning
it’s been regassed, clutch looks like it works as it should when engine running
ran inpa courtesy of mark plant’ laptop- here is what it shows
anyone got any advice as I don’t know what’s good or bad
cheers
Stuart
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
3.0L, 2.8L, 2.0L Z3 Roadsters
A common problem with the AC is the electric cooling fan on the radiator. It needs to be running/working for the AC to kick in.
  1. The electric cooling fan should start and run for a few seconds every time the engine is started. The easy check.
  2. With INPA, look in the DME for fault codes related to the cooling fan.
  3. With INPA, look in the DME, you can test the cooling fan in the "Activation" section. The hard check.
  4. With INPA, look in the DMW, you will see digital indicators for the AC readiness and if the AC clutch has been turned on.
Bigwinn
Lincoln UK
Z4 3.0i
Morning
fan deffo works as I did the activation test on it
will recheck for faultcodes on it
Bigwinn
Lincoln UK
Z4 3.0i
I’ve scanned for codes in cooling fan etc- nothing showing
digital indicators I can see ac clutch on etc
still nothing obvious
i think it’s cooling but not very well when running
Have you had it re gassed Stuart?
Have you had a thermometer in the vents to check how cold it is when running? TBH I would suspect the compressor.
Bigwinn
Lincoln UK
Z4 3.0i
Its cooling but not to the temp as expected- there is a difference between temp on the dial and temp off the vents
The compressor clutch is engaging when the button is pressed- so it spins when on
I may call defeat on this one and let an expert have a look...
Where did you have it re gassed if you don't mind me asking, it's possible it wasn't vacuumed out enough? Should be icy cold from the vents regardless of where the temp gauge is. Tanvic Tyres do re-gassing at reasonable cost.
Bigwinn
Lincoln UK
Z4 3.0i
Ats
sorry Tony went to the competition
Ha, ha. No skin off my nose mate, even more so since I jacked it in.:thumbsup:
Bigwinn
Lincoln UK
Z4 3.0i
Hi all
Going to have another crack at this tomorrow
Got multimeter ready to start to check voltages across compressor, dryer and relay
Any other pointers for me to look at- will fire up inpa again
Checked that the green wire to the fan is ok and the fan works fine
Cheers in advance
Stuart
One thing I would check if you can is correct operation of the system pressure switch Stuart. Seems strange that the A/C “works“ just doesn’t get cold and that points to the gas side I think.
Bigwinn
Lincoln UK
Z4 3.0i
Cheers Tony it’s on the list- will check for power there first
Bigwinn
Lincoln UK
Z4 3.0i
So here is where I’m up to
Can find electrical power at the compressor, the dryer etc
Have lubricated the clutch
Checked fuses
The only thing I’m not getting a happy clean feeling with is the relay
I’m not getting a clear click from the relay area when switching on off
Could this be a relay issue on relay 5 under the fuses?
Thoughts?
Bigwinn
Lincoln UK
Z4 3.0i
Tony I may ask you to send me contact details of your guy in tanvic- would they look at diagnostics for me on the aircon or just check the system pressures etc?
Bigwinn
Lincoln UK
Z4 3.0i
This situation is pretty interesting. I see that you made all the tests so that I won't ask you about them. Did you try to contact a company which deals with this stuff and things?
Not yet- keep meaning to book it in
will keep you posted
Bigwinn
Lincoln UK
Z4 3.0i
Now I've tried Carly and the only 'urgent' errors thrown up by a scan were: aircon!
Codes below- anyone got any insight; google isn't giving me much...
Air Conditioning
Fault code: 00000F
Fault code: 000008
Relay GEBLAESE max / Relay auxiliary fan / Waermetauscher sensor left / AUC sensor / Info AUC sensor / Rear blowers / Dme-ac / Water valve / Free 0x0F / 15 free
Interior temperature sensor in the control unit / Suction errors / Supply voltage RMP / Rear compartment flap motor IHKA / Pressure sensor / Clamp 30 / Nc 8 / Geblaesepotentiometer / Free 0X08 / Waermetauscher sensor right
Auxiliary Heating
Fault code: 0000DA Vorkatsonde 1 signal swing / CDKCHDEV - CAN timeout HDEV / Signal KVA2 / CAN module warning level reached / FS backrest head: blocking front / Internal index 233
Bigwinn
Lincoln UK
Z4 3.0i
I’ve popped my central ac control panel out to see if anything obvious- the sensor in the dash is very gunked up so will see if that makes a difference
I note that I don’t think you can swap hvac control panels out like for like- without coding
But- if the sensor is defective could you replace that? Looks like it unscrews?
You should be able to change individual sensors I would have thought, although you may have to “tell” the car that you have done so.
