Hi,
My year 2000 car's airbag warning light was on when I bought it. The fault turned out to be the clockspring or sqib module behind the steering wheel boss. Sadly I reconnected the battery with a front seat removed and created another error for the belt tensioner. I was totally blasé about this as I have BMW DIS diagnostics and thought that I'd be able to clear the codes with INPA. How wrong I was! The module had locked with a code 240, ECU internal error. You can read the codes recorded but can't clear them until the code 240 had been cleared. This requires the Eprom area of the airbag module to be accessed and cleared by a specialist. Code 240 is a software error not a hardware fault.
After much hair tearing (I'm 68 so lucky to have any left!) and internet searching I came across a company in Liverpool offering airbag ECU module repairs with a very quick turnarround. They've been going since 2004 and even at 8:30 on a Tuesday there was a knowledgeable tech available for an online chat. Because of the age of the module I had been refused by 2 similar UK companies but this guy assured me that they could do the job for me. They have a comprehensive list online of the more common ECU modules for which they charge £25 including VAT and return postage. However my module was not listed so their charge is £30.
I posted it to them on the Wednesday morning, they received it cleared it and posted it back to me on the Friday afternoon, I received it on the Monday morning and it has been fine. I refitted it and checked it for codes with INPA and there were no codes recorded.
The company is Crashdata.co.uk and I can't recommend them highly enough. They obviously have all the info for our older model cars. You have to send it to a box number as they protect their address details I suppose for the security of their premises and to discourage personal callers.
The module that I sent them was a Temic MRSZ3 V3.0 part no. 6908896. This module is apparantly ubiquitous for the code 240 error.
Here they are.
And finaly to remind eveyone of the airbag safety rules.
Before attempting any work on the airbag system:
1, Always disconnect the battery.
2, GO AND BREW UP! The airbag control module retains a charge for a few minutes, this is to power the module should the battery be disconnected in a crash. Make it at least 10 minutes AFTER the battery is disconnected before starting work. This minimises the risk of accidental firing of an airbag component.
Always handle the airbag system components with great care and remember what they are, "mini bombs" and store them in a quiet corner.
3, Before re-connecting the battery always re-check your work.
Hope this 'info can help someone out.
Here they are.
