Bill S
- Joined
- Dec 20, 2021
- Points
- 13
I'm in the USA. I have a 2000 Z3 2.5l. I recently removed the passenger seat to replace the worn bushings on the threadscrews and to replace the broken seat belt guide. I was unaware that it was important to disconnect the battery - my mistake. The ignition was turned on after the seat was disconnected thereby causing the airbag dash light to illuminate. I bought a B800 to diagnose and reset the light, but I am only getting an E10 code. I've tried every trick recommended in the lousy manual to get the B800 to communicate using both diagnostic connectors, but it just won't communicate. I have checked the fuses, disconnected the battery while the emergency light switch was depressed, checked for pin 19 (it seems to be in place) and still the E10 code persists.
I'm wondering if another diagnostic tool would reset it. Since I know how the problem was created, I think it is a simple matter of reset and not a more extensive issue. I do not think it is a faulty airbag module. I replaced the seat and the connections are all okay.
I would appreciate your thoughts and suggestions.
