This lid has been loose since purchasing the car (Z3 1997 M44 1.9) around 6 months ago. It seems that there are "lugs" on the front (nearest to occupant) that are not holding the lid in place - think they may be broken. I assume that these are "sacrificial" in that they give way if the airbag deploys, the lid then moving toward the windscreen, retained by the strap (if that makes sense?). This would allow the airbag to do its job.
New lids seem to be available at circa £125 (part number 51458401077). Just wondering if there is a recognised fix for this issue as am a little concerned that any modification to the lid could affect the deployment should the worst happen. Will buy a new lid if needs be, but thought would check with you folks first, before taking the plunge.
Cheers, Ian
Cheers, Ian
