leon69white
- Joined
- Jun 10, 2024
- Points
- 3
Thinking of a Momo steering wheel non airbag question is how or what do I do about air bag warning light ? Does it remain on
Many years ago, before I joined the forum, my airbag light came on and I had the bright idea to remove the bulb. But a faint light still lit up through the hole. No idea what light. Maybe a LED on the circuit board or some other dash light shining through the hole where the bulb was. Couldn't see it outside in daylight. But at night or when the car is under cover there it was. This nagging glow in the airbag warning.If you are doing away with the bag you may as well do away with the bulb.
As yes it will stay on with no airbag not really any way to code out the drivers airbag
Obviously you'll need a half blind mot tester to pass with no airbag.
Stephen.
Not so. My E36 has passed seven consecutive MOT's at three different garages with a Momo non airbag wheel.However, the tester will also have eyeballs, and will see that the steering wheel does not have an airbag - which on a relatively modern car such as a Z3 is an instant fail.
