Aftermarket Steering Wheel Install - Horn Issues!
R60BBA
London
2002 E46 M3 / 1998 E31 840Ci Sport
Hi,
I've recently just bought a Nardi steering wheel for my BMW Z3.
However, I have a slight problem as I don't know how to wire the horn into the new Nardi wheel.
I have a 2001 2.2i roadster and have attached photos (in the below link) of my wiring.
https://1drv.ms/a/s!Ah3t0FgyoZf7gi6Ky5xHeLnPgSXh
Please help!
Brian H
Killin
E36/7 3.0i - E85 Z4///M
Does your new wheel have horn buttons or are you going to have a static switch in the car somewhere?
The six wires you have are:-
Airbag stage 1 - 2 wires
Airbag Stage 2 - 2 wires
Horn - 2 wires
I'll look out the colour codes
R60BBA
London
Horn - 2 wires
I bought a Renown BMW horn button to sit in the centre of the Nardi wheel (see attached photos in the link provided).
https://1drv.ms/f/s!Ah3t0FgyoZf7gjWxGzcjX3cyBHDa
Brian H
Killin
OK, you are going to have to use the original slip ring off the back of the OEM wheel, the wires are as follows: -
BMW Colour Codes - GE/SW & GE/BR
Actual Colours - Yellow/Black & Yellow/Brown​
BMW Colour Codes - GR/SW & GR/BR
Actual Colours - Grey/Black & Grey/Brown​
Horn - 2 wires
BMW Colour Codes - BR/RT & BR
Actual Colours - Brown/Red & Brown​
From the pictures you have supplied you have a kit that is a single stage airbag kit. The wire with the fuse in is a device to fool the car to think it has the steering wheel airbag fitted, you need two of these to connect to the two circuits above.
The other cables you have connect to the terminals on the back of the horn switch using the colour codes above.
David
Shoreham-by-Sea, West Sussex
Z4 3.0si Sport
Horn - 2 wires
Are you sure you haven't got the top two mixed up?
GE = Gelb = Yellow
GR = Grau = Grey
Brian H
Killin
GE = Gelb = Yellow
GR = Grau = Grey
Yep mixed them up, Thanks for spotting this, edited above :thumbsup:
