- Joined
- Jul 30, 2019
- Points
- 17
- Model of Z
- 2.8
Hi All,
Encountered an issue that has me scratching my head. I've installed an aftermarket central locking system onto my Z3, and it works great. In order to make it look a bit more professional I've been playing with getting the hazard warning lights to flash the the car is locked / unlocked. I couldn't see an obvious handy wire to splice into on the wiring diagram so decided to do it via the hazard warning switch.
The CL module has a wire that pulses 12v when the locking is activated. Now removing the hazard switch and checking what's what with a meter shows that there is 12v on pin 2 and if I short this to pin 5 the hazard lights flash properly.
So 12v to pin 5 works.
But.
If I connect the 12v from the central locking to pin 5 on the hazard warning connector only the passenger side indicators flash.
(If you connect it to pin 4 you get the console lights to flash.. funky)
(If you connect it to pin 3 you get a spark and a blown fuse
Any thoughts? I know this is a bit of a workaround, but it should be simple. Is there another wire off the ZKE that goes to the hazard flasher?
Next up.. getting the automatic window close thing to work.
Cheers
Iain
But.
Cheers
Iain
