Aerial Base unit replacement
AGT1953
Glasgow
Z3M
Hi, I am getting really poor radio reception in my 1998 Z3M Roadster. Now I have cleaned up the aerial mounting thread etc, with very little improvement.
So I am thinking it may be the base unit on the way out!
How easy is this unit to replace on my car & is this likely to be the culprit?
A new base unit seems to be quite an expensive part and before buying I thought I would ask on here for your thoughts.
Thanks,
Andy in Glasgow
Aceman
Moderator
Wakefield
///M Roadster
Have you checked power is getting to it as it is an amplified base ?
Brian H
Killin
E36/7 3.0i - E85 Z4///M
It is an amplified base as Aceman states, I have also seen bad aerial stalks believe it or not, all that bending over the years does not do them much good. Early on in my Zed ownership I also found this problem.
Some food for though?
AGT1953
Glasgow
Z3M
Hi, thanks for your prompt responses!
I am just beginning this voyage of discovery and yet to explore either of your suggestions! Just annoyed at this stage at the poor radio performance compared to the actual car!
So, I will check that the unit is powered & consider a replacement mast prior to the base unit.
Thanks chaps,
Andy.
phil.a
redditch
z4
buy a sports exhaust the radio will not bother you then:)
AGT1953
Glasgow
Z3M
Got a sports exhaust - perhaps that is why I can't hear the radio.
Never thought of that!!!
Andy
AGT1953
Glasgow
Z3M
Hi All,
Ok, I remove the side panel for a wee look and find this bit of kit!
I expected to find the aerial & the amplifier unit but that is behind this thing.
It appears to have fluid in it - as I am very new to Z3's I cannot work out what it is!
Help??
Andy.
Brian H
Killin
Hi All,
Help??
Andy.
Hydraulic pump/fluid reservoir for the roof mechanism :)
AGT1953
Glasgow
Z3M
Hi,
Many thanks for the information - I assume you have to move this before accessing the antenna amplifier unit?
Just noticed, you are in Killin - must have passed close to you last Saturday on our way to Arisaig along the A85 from Stirling!!
My flickr page with some snaps:-
https://www.flickr.com/photos/agt1953/sets/72157657055635125
Regards,
Andy.
Aceman
Moderator
Wakefield
///M Roadster
Yes Andy just unbolt from its mount and move it to one side, there is sufficient slack in the hydraulic pipes to allow to do this then you will see the base of the aerial and the power connections.
AGT1953
Glasgow
Z3M
Hi,
Many thanks - will have a go at this tomorrow and check out your suggestions.
Regards,
Andy.
Brian H
Killin
Regards,
Andy.
Closer than you think Andy, I'm not quite in Killin but just near the chain-link dinosaurs ;)
AGT1953
Glasgow
Z3M
Alrighty then!
I think I know where you be.
Andy.
joepig
preston
hi,I would suggest if you are removing the aerial base unit and have the factory fitted alarm and the radio code that you disconnect the battery,the siren will sound but you can turn it off under the bonnet,i caused an alarm system fault because I didn't disconnect it,quite right these units do seem to be expensive
