Archived aerial antenna base
Discussion in 'Archived Posts (Read Only)' started by micklaw, Jun 14, 2013.
  1. micklaw
    micklaw Zorg Legend
    Sep 24, 2012
    454
    153
    76
    broughton astley
    Model of Z:
    1.8 roadster
    hi folks i am looking for an aerial antenna base for a facelift z3 (dont know if there is any difference )
    cheers mick:)
  2. Jonttt
    Jonttt Zorg Addict
    328
    76
    60
    Liverpool (UK)
    Model of Z:
    ///M S54
    If it's the black plastic bit that sits on the wing it's cheap from a dealer. If it's the metal base in the wing ie you have snapped the aerial it's expensive :(
  3. micklaw
    micklaw Zorg Legend
    Sep 24, 2012
    454
    153
    76
    broughton astley
    Model of Z:
    1.8 roadster
    hi john its the bit inside the wing i am after has to be expensive (goes without saying)
  4. board
    board Administrator
    Staff Member Administrator Global Moderator British Zeds M Power
    Dec 2, 2011
    1,379
    68
    88
    Cuiaba
    Model of Z:
    M Roadster
    Fill the hole and make the lines smooth on both rear wings :)
  5. Brian H
    Brian H Zorg Guru (V)
    British Zeds Scottish Zeds
    3,440
    2,495
    195
    Killin
    Model of Z:
    E36/7 3.0i - E85 Z4///M
    Maybe try sending spurs fan in a coupe a message as he is breaking a z.
  6. zedonist
    zedonist Guest
    As per Brian try someone who is breaking, btw this part was fitted to all e36 convertibles including M3, so you can spread your search quite wide part number is 65218375159. Or it is £83 new from BMW
  7. spurs fan in a coupe
    spurs fan in a coupe Zorg Guru (IV)
    2,557
    1,838
    165
    Thanks for the message.
    As per PM
    [​IMG]
    [​IMG]
Share This Page
