advice required
This is what most people fit to their Zeds, an Earls braided clutch line with Clutch Delay Valve delete. They should be able to tell you which one you need.
http://www.earls.co.uk/index.php
Aceman
Moderator
Wakefield
///M Roadster
There is now doubt they have been proven to improve the gearchange but alot people also miss just getting the clutch fluid changed when the brake fluid is changed as it is an involved job due to the slave cylinder having to be removed from the side of the gearbox. If you ask you mechanic to just perform this I am sure it will improve the feel no end. It is also not much more effort to change the hose at the same time so way up the costs first.
