Hi everyone,
Sorry for not posting much since joining - life has got in the way a bit at the moment! I've finally found some time to come to do some 'preventative maintenance' under the beloved Zed and what i (and the last MOT tester in my defence!) had thought was 'surface rust' on the inner sills has turned out to be much, much worse than feared. The extent was revealed after a good poke with a screwdriver To make matters worse, the car has just had £1500 spent on the oily bits (new head and headgasket/chain/camsaft seal/chain guides/front brakes/springs)
I am sentimental about the car and would like to get it fixed up if possible (it's an MOT failure now if tested tomorrow!) Question is, has anyone here ever had to fix one this bad (see pics) and given where it is, is it even possible to get it MOT passable at this point?? Would be such a shame to lost it as mechanically in most areas she's now very sound .....
ou
I would like to get the outer sill off to see the true extent of it but i understand it is a bit difficult without it being on stands (which i dont have) ...
ou
