accelerator sticking
stevie_a
Glasgow'ish
As title said my accelerator is sticking, it is just at the start of travel
I also have the same problem with my E46
I have used spray grease ( lots of it ) on the joint on the floor, top of peddle and at the top on the bulkhead with the spring on it.
it still sticks
is there somewhere that is prone to sticking that i have not greased ?
Stevie,
This can be a fairly common problem. Have you tried forcing lubricant down the throttle cable sleeve from the engine side? I guess silicone spray would probably be the best, but some say WD40 (and yes I know WD40 isn't a lubricant!)
Gary
si-forks
worcester
Hi i had this on my M44 1.9 and all it was is a build up of muck in the carb remove the pipe from the air box to the carb and give it a good clean i think i may of took the carb off any way 20 min job and it was fine no sticking, sorry i'am not more technical but i think you should know what i mean
Si-forks on tapatalk
stevie_a
Glasgow'ish
Not yet, my wife has just took the Z3 out so will have to try and see if i can fix her E46 by putting some down the cable... :(
I have been using this , it is not to bad.
Martint
Bolton
Does anyone know how to get the cable attached at the engine end . Seems impossible
Martint
Bolton
I can't seem to get my new cable attached at the engine end
bertiejaffa
Manchester
Z3M
If its the same as my 2.0l you would be best off using a mirror - the ball of the throttle hooks right under and back on itself - very easy to do - 10 seconds after using a mirror - little dentist mirror from halfords or screwfix with a magnetic end to collect dropped bolts - comes in very handy too
EDIT - @Martint... I recognise your thread now and yours is the 2.0l - hate to say I already told you so but.. https://zroadster.org/threads/hi-ju...cing-how-difficult-a-job-i.11634/#post-184941
