ABS & Traction Control Light
Discussion in 'Z3 Roadster & Coupé' started by laurence, Nov 30, 2013.
  1. laurence
    laurence Regular Member
    Oct 18, 2013
    56
    15
    21
    Plymouth
    Model of Z:
    2.8
    Hi all,
    New little niggle has come up on my 2.8.
    the ABS and Traction control light will turn on together this its rare for it to happen and 90% of the time if i turn the engine off and on again it will clear it self i have had a quick look at the wheels all cables are intact could it be a dirty sensor somewhere??
  2. zedonist
    zedonist Guest
    It can be a dirty sensor, faulty sensor, or if you have non than standard wheels, it can trigger the sensor, especially on uneven road surfaces, mine play up at the same spot every time on the road approaching the M6 where you have to drive in the ruts made by the lorries, turn the engine off and back on and they clear. If it is a faulty sensor then the fault should not clear. If it is a dirty sensor a good squirt around the brakes should cure, but is worth investing in low dust brake pads.
  3. laurence
    Oct 18, 2013
    56
    15
    21
    Plymouth
    Model of Z:
    2.8
    awesome thanks the pad and discs are bran new i got a feeling could be a dirty sensor i don't believe they are stander alloys i have 17" alpina alloys
  4. bruce&kim
    bruce&kim Zorg Legend
    Jun 15, 2013
    436
    164
    69
    Did your fix on the leaking roof work Laurence?
  5. laurence
    Oct 18, 2013
    56
    15
    21
    Plymouth
    Model of Z:
    2.8
    nope not yet I'm completely stumped on that
  6. zedonist
    zedonist Guest
    Nice choice in wheels, had the Alpina reps on mine loved them
  7. laurence
    Oct 18, 2013
    56
    15
    21
    Plymouth
    Model of Z:
    2.8
    thanks there great a right pain to keep clean though! but worth it once they are just need some 15mm spacers on the rear and will look lovely
  8. laurence
    Oct 18, 2013
    56
    15
    21
    Plymouth
    Model of Z:
    2.8
