PSD
I have a problem after removing and replacing my ABS pump - we have bled the brakes (about 5L of fluid) and the pedal is still very, very spongy. I was looking to repeat the process, but this time with the ABS pump active as per the guidance and was looking at the iCarsoft BMM V2.0 to do this. I am struggling to find out if its ABS pump activation capability works on a MK1 Z3? Can anoyone with this device confirm if it is works on the Z3?
Thanks very much in advance.
