Strange one this and I'm not sure where to go with it. Btw it's not a regular ABS warning lamp on what do I do. I've fixed and reprogrammed replacement modules various times to fix that.
I was aware previously the ASC button was doing nothing which seemed strange. And I've never seen the traction light come on in use. So I had my suspicions.
The MOT tester has now pointed out that the ABS warning light is not coming on when the ignition is activated. This clearly suggests it's not passing required start-up checks. I hadn't in all honesty spotted that light not coming on previously.
So I've got to conclude the ABS system is not operational.
Here's the big BUT though. The dash warning light does not come on in use (and as above it doesn't come on during ignition. AND there are no error codes.
I could just change out the ABS module and that's about all I can think of at the moment. But I previously replaced it because it was throwing an error and it coded up with no problems which I wouldn't expect if it was duff.
I guess there's a possibility too the warning light is blown and the resistance is high causing the system not to power up. But then you'd think there would be an error code.
So I have 2 things to try but experience tends to tell me if there's no logic to why you are replacing something it probably isn't going to fix it.
I'm at a loss as to what is going on! Ideas please!
