So the front drivers side ABS sensor has been replaced after it was damaged.
The hub was also changed as the light would not go out.
Turns out the sensor was not properly ‘plugged’ in and this was the cause of the light being on.
Now it’s been off for a while but recently if I hit a bump it comes on again and goes off sometimes after a while of being parked (not always) and back on again.
So seems like it’s loose somewhere. I’ve had the wheel off and checked the connection thatbs housed on the body of the car in the wheel arch (under the plastic flap).
Seems ok.
Looking at where it sits on the hub side it has a Tort/Allen bolt holding it in place. Could the issue be on this side and what sort of movement could it be as it seems bolted in place?
I’ll try and get the wheel off again this weekend and poke about but any pointers would be helpful as not too clued up this stuff.
Seems ok.
