new to the Z3 and was having typical misfire issue which garage found to be DISA valve. Anyway, go to pick it up and the ABS light is now on, coincidence or not?
Working on the DISA will not bring up ABS codes. You need to get the ABS scanned to find out why the light is up. Use a good scanner with BMW software. Most scanners only read engine computer (DME) codes and not the other computers in the BMW.
