A real shocker !!
Well, it was the Spring really.
Testing a Peugeot Expert van this morning I'd already noted that the O/S headlight was quite low and suspecting a broken front spring I didn't bother to adjust it. Anyway later on the real reason the light was aimed low came to light (sorry).
The upper spring cup has gone right through the corroded support under the inner wing.
Surely to God that can't have happened in a year unless it's been sat in a deep puddle?
That's not good, how old was it?
Was a 54 plate Mike, a year newer than my Z. Best have good look at mine then.=))=))
You should've seen the next one of the same type the guy brought after dinner, it blue smoked so bad I refused to have it running in the workshop and refused to have it running to carry out a brake test either. This one was a Y plate.
