NawidDaoud
Hi all,
I've been plagued by a number of issues recently. Just a few of which below I'm trying to get sorted.
1) Battery drain
My battery has started draining and dying overnight. Jump starts/ trickle charges fine. I found the typical issue of a short in the wiring loom going to the boot lid. A video with phone in the boot showed the boot light was not turning off when I shut the boot as it should. I took the bulb out of this light, but the battery drain is still an issue. It still died overnight. Not sure if taking the bulb out should have solved the problem or not?
Anybody know what the wiring harness fix is? Do I need to remove the rubber harness housing and check if any of the insulation to wires is worn away? If so should I just wrap in a bit of rubber tape to re-insulate?
My airbag light is still on from when I did my seat bushes, could this be an issue?
2) White smoke from engine
Another more concerning issue is that I had white smoke pouring from the engine bay (from the driver's side) and through the vents last time I drove it. Smelt a bit like burning clutch, but the smoke was a new development. Has anybody had this before? And know what the problem might be? Stuff I'm reading online is talking about a valve cover gasket leak. Is there a way to diagnose this? I'm afraid to start the engine for fear of causing damage.
1) Battery drain
