A little help / guidance please
Simon Blythe
South Birmingham
ive finally source a passenger seat base as the motors have failed in mine. The seats are standard, non heated electric seats however, before I jump in, is there a guide on how to swap them over?
Secondly I've replaced the passenger window motor but the rearward a runner doesn't seem to want to sit in bit the window or the plastic clip - I must be doing something wrong but I'm not sure what it is
As always any help is greatly appreciated.
Should of said earlier, I have a spare set of seat motors. They are very easy to refurb. Get yourself some torx keys to undo the screws on the motors.
Is it jammed fully in one direction ? I've found the lead screw to be the problem in the past. Unbolt it at the silver box end and turn it with something large then re grease the screw see if it spins freely.
Antm72
South Yorkshire
You can just swap the base frame its two bolts into the seat base and 2 hook like fittings.
It should be fairly striaght forward :thumbsup:
