A Couple of dead simple questions
JayPee48
Hyde, Cheshire
Z3 2.0 Roadster
1. How do I reset the analogue clock? I need to turn it back one hour to GMT.
2. My windscreen wipers work on intermittent then when the lever is moved to the standard wipe position the wipers are still intermittent, then at the next click of the lever they go to fast wipe as they should. Any ideas?
hard top
Dutch Zeds
Netherlands
Does this still happen, lets say, when you are diving at speed on the motorway?
Your analogue clock has to small buttons at the bottom of the dial which you can press with a pen or similar. Don't use anything too sharp though.:)
TaffZee
Near Llangollen North Wales
Z4 3.0 SE
The window wipers are linked to the speed sensor, and will automatically go onto intermittent when the car is not moving.
So:
Position 1=Intermittent
Position 2=Normal Speed+ linked to speed sensor and will go intermittent when stopped.
Position 3=Fast
JayPee48
Hyde, Cheshire
Z3 2.0 Roadster
Thanks for that Tony.. simple when you know how!
JayPee48
Hyde, Cheshire
Z3 2.0 Roadster
So:
Position 3=Fast
Thanks! I haven't actually tried the wipers when driving. Only just got my first Z3. I didn't realise the wipers were intelligent!
littlefeller
evesham
So:
Position 3=Fast
position 3 will move at position 2 speed (moving speed, not stationery) when not moving
coor thats confusing
littlefeller
evesham
just to confuse things a little more - a programmable intermittent wiper module is also available, some z3 appear to have been fitted with them as std.(not mine though, so im going to fit a vw 99 relay)
im in no way connected to the site in the pic, its just a google image.
