ok folks i have a small problem. i need to fit a seamless tube inside another seamless tube which when fitted will be gas tight, now i cant fit an o ring as the tube walls are only 1.6mm thikness, now here is the question - the inner tube has an OD of 19.05mm and the tube it needs to go into has an ID of 18.96mm so how close does it need to be for me to heat up the outer tube and push the inner tube inside so as when it cooled it didn't deform the inner tube and allow gas to escape?
