A/C Experts please?
Medskipper
Surrey
Z3M & Z3 1.9.
My Z3M a/c is not working.
I went to have it Re-gassed and the guy says my condenser is knackered!
I have a contact who can sell me one off a BMW Z3 2.8.
Is it the same as a Z3M or do I need a different one?
any a/c experts out there?
thanks
Medskipper
Surrey
Z3M & Z3 1.9.
Yes I will thanks, I’ve not stripped it off yet! Just wondered if anyone knows!
Dino D
Kent
2.8 Manual
I recall a post on here about the AC bits for a Z3M. Think it was @bertiejaffa or @Pingu or someone with an Estoril blue one.
Try a search of the forums should be in there somewhere
Medskipper
Surrey
Z3M & Z3 1.9.
Does your condenser and therefore system have a leak?
yes indeed! The engineer coupled it up with gas and it sounded like a steam train!
Pingu
yes I’ve got the S50 engine
Search on the following part numbers...
64538391416
64539113678
64538378613
It looks like it is...
Mahle AC512000S
Hella 8FC351305071
Behr 70816526
Salvage for £70 (or less)...
Medskipper
Surrey
Z3M & Z3 1.9.
64538391416
64539113678
64538378613
Mahle AC512000S
Hella 8FC351305071
Behr 70816526
That’s great thanks Pingu, soon as we get a dry day again I’ll strip the old one out
and check the part number. It’s been pretty wet in the U.K. for a couple of days! Got to look after myself cos I’m knocking on a bit 😀
Pingu
If it's an original, the number is on a sticky label on the top of the condenser. You will need to remove the slam panel to see it.
You will need a new dryer as well once the system has been open to air, don't get it regassed without one, it wont work correctly or last.
If you get it rebased properly you shouldn’t have to replace the drier. A good machine will vacuum the system (with heat) to remove any moisture.
Ton.
Mario
I would buy new which Is what I have done on mine - they are cheap enough it would be a false economy to put a second hand one
Ton.
You're not wrong, but I have a mate who does car and commercial AC for a living and he says once a drier is saturated from open to air it's not always reliable and wont work as efficiently so for the sake of £50 a new drier is always the best option...........Just saying
