Geputten
- Joined
- Sep 16, 2020
- Points
- 6
Hi All.
Help!
We have a '97 1.9L (M44) Z3 here in the US that had overheating issues that I remedied with a new radiator, thermostat, fan switch, hoses and belts. Overheated a lot with my wife not noticing until steam rising. Took the car to a local shop to do a leak-down test and all was ok. Wife took the car on a trip, a 100 miles in and the gauge pegged hot and car died immediately (according to her). Towed it to my previous shop and all cylinders maxed at 40-50 psi. Catastrophic gasket failure? Stretched head bolts?
The shop recommended looking for a used engine, but this one only has 100K miles and everything was just fine before the issue. Besides, everything I'm finding is well over 100K.
Shop said that BMW's can't be rebuilt due to the head bolts rip out the threads....
Ok, here's what I have for questions:
1. Timesert inserts. Can they be applied to the block while engine is in the car or do I have to pull the engine? Has anyone out there done this successfully?
2. Regarding used engines... Mine has the California spec electric Air Pump. Can a non-air pump be retrofitted to my car by transferring over the pump components? Or is the application structural?
Like I said, I prefer to just fix what's broken. I've done a dozen or so head gaskets in my time, but never a BMW. Not sure why head bolts stress out the block so drastically...
Thanks in advance. Happy Motoring.
Help!
