97 Z3 6 cyl. I did the center support bearing , it was torn to pieces. I looked at the flex coupling which had been changed and looked fresh. It was also in the correct orientation. Glanced at the trans mounts they looked alright. I'm thinking now I should have done a little prying on them to see if they would separate. And I should have replaced the flex coupling because I have a new one.
Anyways it's still thumping, but only in 2nd at about 3k, all other gears and rpms on.
I ordered the trans mounts, and thinking I should get another center support in case that new one is already torn. I did try to preload it 1mm towards the trans...I got a little on it but it was at the north end of the slots.
