Just noticed the 3rd brake light on the boot is not working. Any advice on what could be wrong.
Auto electrics are really not my thing. How do I check it?Boot loom?
Thanks Tony. As I said, I know nothing about electrics so I will have to find someone who can test this for me.Loom of doom Paul. Disconnect the plug from the light and check for live when brake pedal is pressed (ignition on). Connect test light between earth and both terminals at a time. If you get a live then connect between both terminals of the plug to see if you have earth.
As Tony says, there are 20 led lights. Surely they can’t all fail at once.Bulb !!!
check the the obvious first![]()
Good pointAs Tony says, there are 20 led lights. Surely they can’t all fail at once.
OK. Will have a look there first. Thank youHave a look at the loom of doom where it comes into the boot near the forward RH corner of the boot lid and look for any signs of breakage.
Thanks Tony..Was on the left side on my Z3 Paul.
Sorry Tony, I was facing the wrong way.Was on the left side on my Z3 Paul.
I did indeed mate and heres my inspiration thread from @TaffZeeYou can use led strips just use the old circuit board as a base. @Sean d did his like this IIRC.
