Hi Geoff, quite easy to remove, just take the pipe off the pump that goes to the jet's. Remove the two bolts on the bulkhead and pull clear, be careful there is a grommet at the bottom where the spigot on the bottom of the bottle goes into the chassis. One of the problems with these bottles is the moulded bracket at the back sometimes becomes detached from the bottle. Hope this helps. Pete.
