Hi All
I've got a 3.0 that seems to not want to play any more.
Symptoms are:
Got it out for its MOT after a long lay up, drove around fine, then on the way home slowed down to go round a junction, low revs the car wouldn't accelerate or rev, almost like the throttle cable had snapped. Minute or so later and it suddenly went again, all fine.
Took the car out a couple more times and it started to do it with more regularity.
Read the codes and its P0102 Mass or volume air flow circuit low input.
I've taken the Maf out and sprayed all the way through with contact cleaner, reassembled and now the car idles roughly and won't rev at all! (progress ... not!). I've tried disconnecting the cable and this makes no difference.
So i'm after some advice about where I go from here? I'm guessing its an electrical issue somewhere but i'd like to make sure that I have ruled out as much as possible before spending ~£200 on a new maf sensor!
Any pointers would be gratefully received!
Symptoms are:
