Wanted 3.0 disa valve
Brian H
Killin
E36/7 3.0i - E85 Z4///M
May I ask is yours broken? You can get repair/upgrade kits for disa valves quite readily.
pgunter
Winchester
2.2i Sport Zedshed Special
Well I hope this might help in your search. You will find on realoem.com normally a list of the other BMWs that the part was used on. As you can see. It was well used.
Firstly try @spurs fan in a coupe Andy might have one, also as the unit was used on an E46, you might be able to purchase one from the breaker I source parts from. If you mention Paul with the Zed3's sent you he will do you a better price. His name is Nick Jupp Google German Car Spares Kent. I have his mobile which I will pm you ok.
Hope that helps.
pgunter
Winchester
Niall @Nodzed its the actual casing that is split on Simons Disa valve. Those kits seem good too.
Ah I didn't read that properly then, no wont help if the casing is cracked.
pgunter
Winchester
Typical manager..... read the whole document.... =)) and you being Health and Safety too.. Jolly Bad Show old boy..
