Rick A
- Joined
- Aug 18, 2019
- Points
- 18
Apologies in advance as I unfortunately haven't been very active on these forums. Am hoping to find my lovely Z4 a good home, where it will continue to be well looked after.
56 Plate BMW Z4 E85 2.0i Sport - 118k miles
Extremely rare Deep green Metallic with black interior and Aluminium dash trim
Desirable M-Sport spec seats and steering wheel
M-Sport 18" Style 135 MV2 wheels
Exhaust Back box delete by Proflow. Sounds amazing (original backbox from a similar mileage car available)
Working cupholders retrofitted
Bluetooth music module added. Works like a dream
Weighted ZHP gearknob - makes it a joy changing gears
Debadged with stubby aerial for a cleaner look
This has been my daily car for the past 3 years, during which I've had the following done -
Full Suspension refresh with new shock absorbers, springs and top mounts front and rear
Front Lower wishbone bush
Front drop links replaced
Wheel bearings replaced
New clutch kit fitted
Wheel alignment
New engine coil packs
Exhaust valve stem seals
New engine sump and gasket
Vanos solenoids and vanos unit bolts replaced
New rocker cover gasket
Roof motor and pump head replaced and relocated to boot
Nearside window regulator replaced
New nearside Front brake disc shield
Exhaust centrebox mounting
Clutch Delay valve removed
New third brake light
Glovebox replaced
In the past 18months alone -
Full brake upgrade with bigger discs, pads, calipers and carriers, hoses and sensors from 3.0i; for better stopping power
All brakes bled including brake fluid service
Calipers painted
New brake servo and vaccum pump
Handbrake lever replaced
New front lower arm and bushes
New rear wishbone bush
New front anti roll bar link
New rear shocker top mounts and top mount bushes
New starter motor and ignition switch
Fitted new camcover gasket
New valvetronic sensor seal
Coolant pipe replaced and engine coolant refilled
New expansion tank
Electric fan replaced
New radiator and condenser
Aircon regassed
Pirelli P Zero tyres in correct sizes on all 4 corners
Headlight restoration
Brand new wheel bolts
New bulbs all round, floor mats and wiper blades
I'm sure there are things that I've likely missed, however I have receipts and invoices for all of the above. All work completed either by BMW Independent Specialist or my trusted local garage
Full service history. 11 stamps in the book.
Full major service (inspection 2) in Jan'24. MOT until Jul'25
Private plate and V750 certificate included in sale.
HPI report available
2 keys
Based in Nottingham, although I do visit family in London / Heathrow area
£3,995. No offers please
Wheel alignment
Glovebox replaced
Calipers painted
New expansion tank
Aircon regassed
2 keys
