2000 Z3 wiper relay location
MattInSV
Hello I have been looking online and searching here for the location of the wiper relay because my wipers seem to work about half the time I turn the car on and reach for them. They either work perfectly or I get nothing.
the manual doesn’t show the location of the relay. I found a diagram with three fuses online which are all good. I also found a diagram that shows an R3 in the engine compartment fuse box but I don’t even have the three relays R1 R2 R3. And the box label doesn’t identify the relays, only the fuses. 😡
Another diagram shows some auxiliary panel on the left side of the dash but I can’t find it. I dropped the cover above the pedals and I can see where the wire harness comes through the firewall, but no fuses or relays I can see. 🤔
the bimmer forum had a thread with a bunch of broken images and people saying thanks. It must have been good post at one time.
Here’s the fuse diagram I found online:
According to the Bentleys manual, there is a wiper and washer control module "behind the glovebox". This has four relays, three switches and a 'feedback contact' relay.
Bear in mind the Bentleys is US specific, so the module may be on the opposite side.
Thanks I will check this out. Mine is also US spec. It’s surprising in a car this small they hide things everywhere! Tracing intermittent electrical problems can be particularly difficult.
Please note that the Z3 wiper system has a speed signal in the control pattern.
- Driving down the road, the wipers work as normal
- Stop and they drop down one position automatically. Wipe becomes intermittent, intermittent becomes stopped etc.
- Start driving and they automatically go back to normal operation.
This means, that if you are sitting in the drive, testing the wipers, they do silly things and appear to be not working correctly.
Thanks I have had the unfortunate opportunity to confirm non-operation on the road at speed. In any case, the manual mist wipe (press down on the wiper lever) should always work, right?
