Just to make my day complete....
They have just put Pistachio on the ramp and now tell me that the front coil spring has snapped and damaged the front tyre as well. So on top of water pump etc, I also need front end suspension bits replaced!!
It may be even slightly worse again. Make sure you take control of the spring fitted. Assuming it's still on factory springs, Sport fitment is -15mm. There are no aftermarket parts. Only BMW. Front springs are about £85 ea from BMW. And preferably replaced in pairs.
Other options are change springs all round and lower by a further 15mm (-30mm fitment). Or have a pair of regular aftermarket springs that will increase the front of the car by 15mm. Don't do that on one side only otherwise you will affect handling - exactly why you shouldn't let the garage pick. They may well tell you they put in your reg and it's the right part but I can tell you know with all certainty it won't be because you have a Sport. Every single parts catalogue I've ever checked does not know about Sport fitment and I've checked dozens.
While the strut(s) are apart they should check the shocks have good rebound and the top mounts are okay. If they are original factory shocks it will be a big surprise if they are in good order.
The good news is all of this is fairly light on labour. It's the parts bill that stacks up.
