2.8 pre facelift suspension
id101
Hi all,
Would I be able to fit the 2.2 sport suspension on my 2.8 pre facelift widebody?
If so, would it give a slight lowering affect but keep a nicer feel than going a full lowering route? As currently my stock suspension is very high but with the state of the roads I'm thinking lowering might be too much
Hi all,
Swapping over the shocks and springs will be fine.
You'll be better off buying new shocks and using the 2.2 springs to get the 10mm ride height reduction.
id101
So find the OEM shock for those springs?
Dakar Z3
Dakar
Sunderland
Z3 2.2 , Z4 Coupe 3.0si Auto
Hello,
You can use your existing shock absorbers front and rear if they are in good condition, it is the springs that determine the ride height not the shocks.
If you decide to change to the 2.2 sport springs it is advisable to change front and rear top mounts at the same time.
Sajk
Hi all,
Those springs don't still have part number tags on do they?
Redsheep
Aberdeen
Did you buy sport springs?
Would be interested to find out approx. cost and part numbers for these from BMW
id101
I didn't no, haven't bought anything yet. Still undecided on what to do
