Tim Davis
Its all been running so well and smoothly. But engaging gear from cold start has got harder and harder to the extent that I can only move having cold started with the clutch depressed. Once on the go and warm, it changes fine. My trusty spannerman has diagnosed bush and or bearing failure and a strip/rebuild. Price awaited and he will outsource it. Not welcome, but makes sense, even if it's only got a modest 96k under its wheels. So, dwellers of the Midlands and Shropshire who may have had the same issue - can you recommend any gearbox specialists? Thanks in advance. Tim
