2.8 Decat
Mole
Messages
5
Gillingham, Kent
Hello,
I've been looking around for a decat for the z3 2.8, but have yet to find one.
Mine was made december 1997, but reg'd in march 1998, so I believe only has a lambda sensor pre-cat.
If there isn't an 'off the shelf' type product, what about buying a pattern front pipe/cat, and cutting the catalyst out and putting a pipe in its place?
Any ideas or help would be very much appreciated :)
lmrdave
Messages
31
Lincolnshire
Z3 2.8 pre facelift
If you really wanted to get rid of the Cat you will have to cut it out and have a replacement fabricated as it's not straight in and out from memory. If you are intent on doing it I'd weld in a flanged joint and weld flanges on the CAT so it can be replaced for the MOT (or as you say have a complete front pipe spare iwth cat and new one without).
Personally I would not bother,. you'd be better off replacing the or moding the back box, as I believe the main flow and noise restriction is there.
ShoutyRedCar
Messages
I had exactly that modification done a few years ago. I had the cat cut out and flanged, with a replacement flanged bypass pipe made such that the cat and the bypass can be easily swapped - takes no more than 20 mins to do. This was done at MIJ Performance in Walsall, who also replaced the stock pipe from Ccat back with a stainless mid-sport pipe. The difference in power is immediately noticeable, the engine flows much more freely, and revs with increased power through to the red-line. Worth every penny!!
Z
zedonist
Guest
I was going to suggest MIJ Performance, looks like someone beat me to it!! :)
Lappintyre
Messages
28
I had my standard cat gutted a few weeks ago as it was shagged, the car is going great since, so much more torque and a beautiful sound too. Mot didn't pick it up either
Z
zedonist
Guest
What engine is that on, and do you mean you emptied the cat so it is in place but has no cat material?
Mole
Messages
5
Gillingham, Kent
Unfortunately MIJ is a little too far away for me, but I'm hoping to visit a local exhaust place at some point over the weekend. If they won't quote me on doing the decat, then I think I will have to buy the cheap pattern catalytic converter and just remove the cat material like you did Lappintyre.
If only I had a mig welder!
