2.2i Brake calliper removal. Stuck bolt
DivideBYZero
Surrey
Z3 2.2
Hi all,
I searched, but got little on this.
My 2.2i has the ATE 54/77 Callipers and supposedly they have 18mm bolts. Not mine! They’re 16mm. Got the lower bolt off using a breaker bar, but the upper is really stuck and I can’t get my breaker in there as the hose fouls it.
Any tips? At this rate I’m going to have to wait to take it to my specialist when things are more normal. Which sucks.
Thanks all.
Dino D
Kent
2.8 Manual
I use a breaker with a ‘wobbly’ head to get in there.
Paul Rice
Doncaster
Z4 2.5 E89 23
Is it the carrier your trying to remove? If so have you removed the caliper first?
Mazza
Bognor Regis
As Paul has said above.
Just been out to the garage and taken some pictures of mine to help.
If this is the bolt you are trying to remove...
Remove the calliper to get access to the bolt
Undo these and the calliper will pull off the disc. Once off, Don't let it hang on the brake hose though.
Then you can use a breaker bar on that top bolt.
DivideBYZero
Surrey
Z3 2.2
Oh, thanks all.
Mazza, top tip. I’ll recheck tomorrow.
Defo 7mm allen bolts.
DivideBYZero
Surrey
Z3 2.2
Thanks to this thread I got the rotor off, but, the Allen bolt that retains the disc has lost its collar. I’m pretty much f&£ked without it. Anyone got the part number?
I’m off to real OEM to look it up. Sod’s law...
I can post you one.
Go on ebay search 1161806
Same bolt for most BMW and Mini models front and rear .
mrscalex
Some discs will come with new ones.
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
M6 x 20mm countersunk head bolts are £6 for 50 from Screwfix.
DivideBYZero
Surrey
Z3 2.2
I can post you one.
Much appreciated, but I’ve ordered a couple. My Z is a summer only car and can live in the garage on jack stands for a couple of days.
DivideBYZero
Surrey
Z3 2.2
DivideBYZero
Surrey
Z3 2.2
Ok, this car keeps fighting me! The guide pin sheared off as I was tightening it up...
FML
Ordered a new set and the half of the calliper that the pin bolt in to, because forget drilling that out. It’s in for life...!
DivideBYZero
Surrey
Z3 2.2
At least I got the disc bolt int he mail and buttoned that up.
Small victories...
What usually happens with the slider pins is they strip the threads. You can drill it out and heli coil it. It is a 9mmm thread though.
Tony
