I have 2 original BMW complete exhaust systems. Both appear to be in good external condition but I have had neither on cars I have run.
One has been cut in half for removal (ie needs sleeves to reinstate) and has the manifolds still attached to the front section.
The other is complete but has a stub of the manifolds left on the other side of the flange where they were cut for removal.
Both systems have been removed (albeit with different approaches) due to the nightmare to remove system to manifold flange bolts.
So you will need to do a little engineering to prepare either system for use.
2.2 exhausts are not the easiest thing to find second-hand (and many will have the issue these do) so they are worth considering.
£125 for either system. Collection only from Swindon.
