1999 Z3 Relay identification
george hunter
1999 Z3 roadster USA car.
I'm looking for a layout and ID for the relays that are in the DME enclosure under the hood in the rear passenger side of the engine bay. There are 3 relays, Blue #428, Light Green #388, and pink #348. What is each for.
There is also a fuse holder with 5 fuses. From left to right the first is a 30 Amp. I do not get 12vts at this fuse with the key in run position, the other 4, I do. Can someone identify what these fuse #'s are? Each time I try a search for this area I end up at the main fuse/relay pack at the rear of the left side of the engine bay. Thanks
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
3.0L, 2.8L, 2.0L Z3 Roadsters
Get your Z3's wiring diagram from the "Resources" section of this forum. Look at the blue ribbon at the top of your screen.
In the back of the diagrams is a locations of key items list and photos. You should be able to work through from there.
Z3 Wiring pdf document attached may be of help to you
