PAUL ECCLES
- Joined
- Apr 17, 2015
- Points
- 3
Hi everyone, is the nearside door mirror fixed or should it swivel like the off side?
My near side mirror was also solid, wouldn't move at all, also the base was very corroded so it had to come off, previous owner had fixed it in place with PRC (aircraft grade sealant) which meant one thing that previously someone had tried to fold it and snapped the casing just above the swivel joint. Nothing to loose but to force it around, it gave quite easily, beyond repair. The base was so corroded it was beyond repair, I bought a composite one from Germany complete with base, took it all ( plus drivers side mirror) to my local spray shop who matched it perfectly. Cost a few quid to from beginning to end, but seeing that the mirrors stand out, they have to be perfect otherwise they let the car down. Happy now.Hi everyone, is the nearside door mirror fixed or should it swivel like the off side?
If I can remember I don't think you do, by removing the glass and exposing the Tory screws that separate the outer casing this just leaves the skeleton of the wing mirror and the Allen bolts exposed to enable removal. Mine were solid and it was only by holding them in a vice that I was able to free them up, so I must have removed them first.the only problem taking them off to free them up is you have to swivel the head to gain access to the 2 allen bolts that hold the mirror on to the door
Hi can you tell me the name of the supplier that you bought the mirror from please? I just got a quote from bmw and nearly fell off my chair! thanksMy near side mirror was also solid, wouldn't move at all, also the base was very corroded so it had to come off, previous owner had fixed it in place with PRC (aircraft grade sealant) which meant one thing that previously someone had tried to fold it and snapped the casing just above the swivel joint. Nothing to loose but to force it around, it gave quite easily, beyond repair. The base was so corroded it was beyond repair, I bought a composite one from Germany complete with base, took it all ( plus drivers side mirror) to my local spray shop who matched it perfectly. Cost a few quid to from beginning to end, but seeing that the mirrors stand out, they have to be perfect otherwise they let the car down. Happy now.![]()
Hi Jake, this is the item I bought, they are still on EBay now £83 + £13 postage from Germany, composite material, will never rust.Hi can you tell me the name of the supplier that you bought the mirror from please? I just got a quote from bmw and nearly fell off my chair! thanks
Hi Ztec much appreciated thxHi Jake, this is the item I bought, they are still on EBay now £83 + £13 postage from Germany, composite material, will never rust.
Website also : www.spiegel-z3.de
Good luck
Tec
