1998 Z3 M52B28 Exhaust header for 328?
PeterJ
Hong Kong Zeds
Hong Kong
Z3 2.8 Roadster M52B28
Hi Z Roadster, I have been given this ebay address for a RHD exhuast header (almost impossible to find!) but it seems to be for a 328 and not a Z3. Does anybody know if it is reasonably possible to fit/modify to fit my RHD 1998 Z3 M52B28 ? Cheers for any comments... :D
http://www.ebay.co.uk/itm/92-98-BMW-E36 ... 783803174&
captain
South African Zeds
Durban, South Africa
Z3 Roadster 2.8i
Re: 1998 Z3 M52B28 Ehaust header for 328?
The steering shaft is in a slightly different place on a z3, when I did my headers the first set I tried could not be fitted due to the steering shaft been in the way, they where from a 328i. I eventually found another set locally that fitted, also from a 328i. It depends how the headers are made/bent if they will clear the shaft or not. I would be hesitant to buy a set off ebay unless they say they will fit a Z3 for sure, hope this helps.
PeterJ
Hong Kong Zeds
Hong Kong
Thanks captain....never easy!
captain
South African Zeds
Z3 Roadster 2.8i
No problem Peter, it's never easy as you say, well worth doing if you've changed the inlet manifold :D
PeterJ
Hong Kong Zeds
Hong Kong
Given up on the headers for the time being and the design on my stock headers seem quite good anyway...gone for a Magnaflow cat (direct fit) instead!
captain
South African Zeds
Z3 Roadster 2.8i
That should help, we are lucky over here, its not law to have cats fitted.
Sent from my HTC Desire
hard top
Dutch Zeds
Netherlands
In the 1990's, I imported a Merc from Germany.
On the hard stamping under the bonnet there was no mention of it having a cat.
So I took it off...bhp went up and fuel consumption went down...who is kidding who??
MOT's were no problem, it sailed through
