- Joined
- Aug 2, 2023
- Points
- 51
Could anyone please confirm the underseat connections on a 1998 1.9? I removed mine to fix the worn bush / seat sliding problem - driver's seat worked first time in all directions but passenger now very slow to move; it will move forward slowly, not backwards at all. Before removal it worked fine, so I suspect I've gotten the threads out of sync or otherwise mis-aligned the system. It works slightly faster if the seat bolts are removed and the nuts loosened. I also suspect the new bushes have been fitted too tightly so preventing any movement of the threaded adjusted block as the seat moves about.
Under the driver's seat there is a white plug-in connector and a yellow, with a black tied up and unused. Passenger seat has the same white connector and unused black but a very small yellow / red connector block, almost like an audio connection, much smaller than the one on the driver's seat.
Driver's seat moves forward / back and up / down. Does the passenger seat do the same? The switch appears to move up and down but there is no corresponding seat movement, and I don't know if it's meant to be height adjustable. I don't want to try to fix a fault that doesn't exist; the seat will be removed again shortly for adjustment and correction.
All help appreciated!
