1997 2.8 roadster (auto) keeps stalling at roundabouts and will not restart until engine has cooled down after 30 minutes
stackwadd
Lancaster
Help Please. My 2.8 Auto Roadster (89,000 miles) keeps letting me down, usually at busy traffic intersections! It has the M52 B28 engine.
I have been towed home by the AA three times in the last week. There are no fault codes showing, and no dashboard lights on at all. I have had a professional mechanic change the fuel pump with a quality replacement pump along with a new fuel pump relay. Car starts and runs beautifully. Then once it has warmed up, it stalls and will not restart. The battery is healthy. Cranking strongly. Sometimes, once cooled down, it will start again and seems to run fine for a while, only to repeat the previous behaviour - usually at busy roundabouts. I am now in a position that I cannot trust the car at all, as I know it will let me down sooner or later usually in a dangerous spot.
The last AA man suggested maybe the ECU box could be suspect as the fault manifests itself when warm and then reinstates once cooled down. He suggested (maybe) a solder weakness on printed circuit board inside the unit. Please can anybody suggest what I could do next to resolve this? I am totally out of ideas, and have already spent quite a lot trying to get this fixed. There were no fault codes whatsoever showing when I had a diagnostic done on professional equipment. I cannot use the car anymore until I get this sorted.
I would suspect the inlet camshaft position sensor is faulty. When mine failed on my 2000 2.0 the symptoms were remarkably similar.
ps. Do not use cheap aftermarket (eBay) items. Use only OEM quality part if you change it, or swap it with a “known” good one.
stackwadd
Lancaster
Thank you for your reply Tony. I will follow up on your suggestion.
Kind regards
Mark
Robert Hill
I sent my ECU to ECU testing and had it rebuilt with lifetime guarantee it was collected from my home on the Monday and returned on Friday plugged it in and have never had any problems cost £350 including vat and delivery look them up on YouTube
stackwadd
Lancaster
Thank you for your post Robert. That is very useful. Your car looks the business.
Kind regards
Mark
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
3.0L, 2.8L, 2.0L Z3 Roadsters
When it refused to start, does the rev-count bounce up a bit when you are cranking? It should do. If it does not, then your crank sensor is failing.
stackwadd
Lancaster
Thanks for the post NZ00Z3. It is appreciated. I will check this next time it fails.
137699
Hampshire
M Coupe 3.2 S50
Just noticed this is posted in the "Z3 M" section for S50/S54 3.2 litre engine cars - you might get a better response if you move it to the non-M section.
stackwadd
Lancaster
Zorg Addict. Thanks for your comment. I have copied it over to the non-M section. Unfortunately I somehow managed to post it there twice!
guyglemieux
Canadian Zeds
St. Jerome, Province of Quebec
Z 3
I once had a car that would stall on me once it warmed up. I was a bit at my wits end when my father-in-law suggested that the distributor coil can break down when too hot. Sure enough changed it and no more problems. This is just a thought I had.
Good Luck.
