Daspete
- Joined
- Jan 13, 2019
- Points
- 60
Hi guys
Had my differential rebuilt a couple of years ago whilst rebuilding most of the car but only got the car back on the road in may and it's apparent they did a bad job.
I get a clunk from the diff when I change direction and from a spirited pull off from stationary. Seems there's quite alot of backlash which I did ask them to check. I didn't really have any before but now it does.
Had an oil leak from the diff too. On closer inspection I found the drive flanges are literally floating in and out with no resistance so the retaining rings must be missing or incorrectly positioned as well.
Decided I'm going to sort it myself and I have the equipment.
However does anyone know how much backlash is permitted in that diff?
Assuming it's just adjusted using the large shims under the side plates?
Thanks in advance
Thanks in advance
