      8 votes
      BMW Z3 Sill removal and protection
      Article supplied by z3cade (Liam)
      Jack up the car and place on axle stands
      Remove wheels
      Remove rear arch liner
      Remove kick pannel trim and door rubber
      Remove kick panel plastic plug
      Remove kick panel by lifting up
      You may brake some plastic clips so remove broken clips from holes
      Remove front arch liner
      Remove screw from front arch, top front of sill (use 10mm ratchet)
      Remove three screws for the small side panel, detach side repeater and remove
      Get a friend to help, but a good friend not a nutter…
      Remove screws from under the sill
      Remove screw from rear arch
      Remove small plastic trim from inside door and remove bolts that hold rear arch to allow better access for the screw behind it
      Remove final bolts from top of the sill that were under the kick panel and remove sill
      Clean up box section and check for rust
      Treat areas with rust with your prefered products
      I used zinc 182 primer, clear Waxoyl spray for inside box sections and original Waxoyl underseal
      Treated rear box section
      Treated front box section
      Sand down any rust found on the sill and treat with your desired products
      Now just reverse the removal process and replace the sill, Job done
