BMW Z3 Brake warning light reset
Article submitted by Swamper
Make sure that you replaced the sensor and the brake pads, if you did not replace the sensor or pads this will not work.
Turn the key to position two (when all of the inspection lights are lit), leave it in this position and leave your driver’s door open a few seconds (between 15 to 90 seconds depending on your car) and it magically resets.
If that did not work turn the key to position two and push down on the brake then turn the key off and check to see if it turns off (door must also be open).
If this still does not work press down on your brake (hold it pushed down) and turn the key to position two and wait until it turns off.
If none of these work please go back and check that you installed the sensor correctly.
  • Like
Reactions: KimbaCat
