#ZedShed Family Owned 2.8 build (Subframe & Gearbox)
Jjim
Messages
3,503
Mansfield
1.9 Roadster & 2.8 Roadster
Great to see the process and what needs doing to mine.
Interesting to see how worn the pins for 5th and reverse were.
  • Like
Reactions: Lee
Messages
3,679
Z3 Roadie 2.8TU
yeah totally agree, what we see is the two guides no longer allow the pin to slide freely so this also makes it hard to remove them. I’ll be doing this exact same process with yours.
Ianmc
Messages
2,423
New Forest
Z3 (M44)
Will you install/reinstall the aircon? Personally consider this essential, especially during the winter months. :thumbsup:
Messages
3,679
Z3 Roadie 2.8TU
I spoke with James who owns this Zed and he told me an interesting story, when his Dad bought the Zed in Germany he had spec’d it with Aircon, somewhere along the way they decided not to install it. The rest of the system is missing so to install it I will need to remove the dash, find a pump condenser etc. It’s a lot of work and money for a car only driven when the weathers nice.
Messages
3,679
Z3 Roadie 2.8TU
Tiny update today. Everything was collected from the powder coaters. Only checked the offending swing arm and all is good. Also got the Gearbox back in and fitted some hardware up front.
The good arm looking like new.
The offending arm turnt out ok, no longer a risk just some signs of previous corrosion.
Gearbox now back in her home just needs a wipe down.
Now the fun begins fitting all the shinny new stuff.
just waiting on new dust shields before refitting bearings.
Tomorrow we’ll be assembling the rear subframe. Stay tuned :)
Matkat
Messages
15
Absolutely brilliant. great to have this picture refurb. 👍👏
  • Agree
Reactions: Lee
Ianmc
Messages
2,423
New Forest
Z3 (M44)
Fair enough and makes great sense. Just my opinion, but I wouldn't even look at a Z3 without aircon when buying. :thumbsup:
  • Like
Reactions: Lee
Messages
3,679
Z3 Roadie 2.8TU
So today was full steam ahead. We fitted the freshly powder coated front roll bar with some nice strong flex bushes and Meyle HD drop links. That now completes the main hardware upfront, just need the brembo discs and backing plates to arrive. Not sure what’s going on with Royal Mail but we seem to only get deliveries every 3/4 days.
front roll bar
also I forgot to show a few photos under the rear with the new straps and being sealed in. We only ever see rust begin on the seems where the chassis is spot welded together.
We also experimented seeing how well some other objects come out being blasted and powder coated. I sent the springs and pin washers. They turnt out amazing.
Now it was onto the main event. We pressed in the new Bilstein bushes and started assembling the arms.
such a clean beam.
arm sporting new FAG bearing
now the shaft gets a quick clean and refitted to the arm.
now the moment of truth. Everything back together.
And a few minutes later installed to the car.
the eagle eyed will notice the new shocks, the old ones performed ok but the corrosion on them was bad.
Now the main reason for the slippy rear and banging over bumps. New Beam bushes sitting high and proud.
Now notice the gap between the plate and bush. Before they were touching.
Not much left to do now. Waiting on brakes, drop links and some front shields. Also have a full service kit with a new rocker cover seal to fit/install. She’s very nearly done now.
Rha
Messages
3,819
Z4 coupe sport.
This looks like another successful refurb in the making.
Gonna be another well happy Z'er hitting the road. Amazing how a shed queen of many years can actually need nearly as much work as a daily driver of same age. Rust and rubber being it seems the main culprit. Well done again you guys.
RHA, Roy. ;)
Messages
3,679
Z3 Roadie 2.8TU
More reassembly today. We collected the last of the parts, all the brake bits along with drop links and hand brake cables. It was also a good time to fit the front section of the exhaust and belly brace.
Shinny bits waiting for assembly.
Be rude not to fit new exhaust nuts. Who knows it might be us revisiting these again in the future.
Coated belly brace
new Guibo/flex disc fitted. After these photos everything had a good wipe down.
Huge tower of brake parts. Brembo for days.
managed to fit the rear roll bar, sporting stiffer bushes to keep the car flatter.
Just before the end of the day I managed to build up one corner. Looks factory fresh.
Messages
3,679
Z3 Roadie 2.8TU
This is by far the best bit of the build, getting to fit all new shinny stuff. The front dust shields arrived allowing me to finish the front.
ront now looks like it’s just rolled out the factory.
Also finished off the other side at the rear, fitted the new pad sensor. Also tidied up the rear offside drive shaft. Final bits on the rear are to refit the exhaust, fit the spare wheel and install the new brake lines.
Today we also took delivery of the new spare wheel. Fits a treat inside the carrier.
Im also waiting on a service kit so I can fit new plugs, James informed me these are 12 years old be interesting to see how they look. Then once down I can take her out to get the tracking done. So close :D
Zag2
Messages
16
Reading, UK
BMW Z3 2.8
I always wondered what's the point of the spare wheel, does anyone actually use it? I'd just call the AA :D
Build looking incredibly good so far, love the shiny bits...
  • Like
Reactions: Lee
Jjim
Messages
3,503
Mansfield
Unfortunately I’ve had to use mine a couple of times. Had a cracked wheel, so a replacement tyre would have been no use. Also had a 7” tear in a tyre so again the spare got used.
Martin Sullivan
Messages
49
This is all a great read!
How much do the shift pins cost? I’ve been quoted near enough £60 per pin, plus spring and caps etc comes out close to £80 per pin x6 = £480!!!!!
That’s just for the parts sourced from BMW.
Messages
3,679
Z3 Roadie 2.8TU
Thats strange it costs around £55 from BMW. I’ve done 4 gearbox’s this year.
Edit: these are the parts you need.
BMW ZF Gearbox Internals
23117525048 – 3x Pin Kit
07119937227 – 3x Sealing cap
23117542726 – 2x Pin Bushing Kit
23311224849 – 1x Reverse Gear Pin
23317502165 - 1x 5th Gear Pin
