How To Guide 3G EWS remote fob programming
Discussion in 'Z3 & Z3 M Roadster & Coupé Knowledgebase' started by jonco, Aug 18, 2013.
  1. jonco
    jonco Zorg Guru (III)
    Supporter British Zeds The M44 Massive
    Dec 6, 2011
    1,498
    728
    149
    Chester
    Model of Z:
    '98 1.9 Auto
    jonco published a new article:
    Read more about this article...
    • Like Like x 1
  2. Aceman
    Aceman Moderator
    British Zeds 3rd Party Trader
    2,226
    720
    156
    Wakefield
    Model of Z:
    ///M Roadster
    Great writeup Jonco this will help out many zed owners new and old so many thanks for taking the time to do this.
  3. Brian H
    Brian H Zorg Guru (V)
    British Zeds Scottish Zeds
    3,619
    2,618
    195
    Killin
    Model of Z:
    E36/7 3.0i - E85 Z4///M
    Good job Jonco :)
  4. GazHyde
    GazHyde The Gaz Monkey
    Dec 2, 2011
    15,485
    9,864
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    Looks a bloody good write up @jonco!
    A great addition to the wiki. Will try and add it tomorrow!
  5. jonco
    Dec 6, 2011
    1,498
    728
    149
    Chester
    Model of Z:
    '98 1.9 Auto
    Most of the kudos is yours Brian - I was following a lot of your previous info and that of a few others.
  6. GazHyde
    Dec 2, 2011
    15,485
    9,864
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
  7. stek011
    stek011 Regular Member
    May 4, 2014
    4
    13
    Model of Z:
    2800
    followed the instructions and it worked but then stopped working and the alarm goes off on every entry to the car and the console red light is flashing. I have tried to reset but with no avail. any ideas? I have changed the batteries in both fobs but still nothing.
  8. jonco
    Dec 6, 2011
    1,498
    728
    149
    Chester
    Model of Z:
    '98 1.9 Auto
    Hi sorry to hear you had a problem. Can you clarify at what stage it stopped working again - immediately or after a number of operations? Are they new or old fobs? Is the red light flashing all the time?
  9. stek011
    May 4, 2014
    4
    13
    Model of Z:
    2800
    Hi jonco the remote worked once when i switched the module to learn then nothing the siren went off and the tell tale light was on flashing at a regular pattern.i disconnected the battery to see if it would reset but it didnt.siren is now switched off but indicators flash on entry to car. And that where im upto. Need help.
  10. jonco
    Dec 6, 2011
    1,498
    728
    149
    Chester
    Model of Z:
    '98 1.9 Auto
    Difficult one to diagnose remotely (no pun intended) but the flashing light and alarms on entry suggest it's stuck in permanent set mode or maybe still in `learn' position. The only thing I can suggest is that you repeat the procedure but then make sure that the slider goes fully back over to normal position. That was the only problem I had, but others have done the job and may have some different input.
  11. stek011
    May 4, 2014
    4
    13
    Model of Z:
    2800
    Thanks jonco. I will try and sort it in the next couple of days. Will let you know how i get on. Steve
  12. stek011
    May 4, 2014
    4
    13
    Model of Z:
    2800
    Hi Jonco, Well I eventually sorted it. It took some messing and fiddling but I had to remove the sender box from the alarm box (prise apart) then there are 8 thin pins on the module sticking up. I then reconnected the sender but left just enough room so I could touch the pins between the two units then I used a thin piece of wire with bared ends and touched each pin in sequence and eventually the alarm tripped off. I then reset it using your technique using the remotes. Cheers Steve
    • Like Like x 1
  13. jonco
    Dec 6, 2011
    1,498
    728
    149
    Chester
    Model of Z:
    '98 1.9 Auto
    Brave move - glad it worked. I know the pins you mean - I started to open up the box but then chickened out and left well alone!!!
